Dore Westbury Mill Restoration
Hi folks :)
Taking my first steps into machine refurbishment as I have a Dore Westbury Mk1 milling machine in desperate need of some TLC.
For those that don't know, the Dore Westbury mill is a unique machine as it was sold in kit form and was designed such that it could be completed using a myford size lathe at home. This makes it a perfect candidate for first time referbishers as it's construction is very straightforward and simple enough for a newbie engineer/machinist such as myself to tinker with and fix.
Detailed info about the Dore Westbury can be found on lathes.co.uk here:
http://www.lathes.co.uk/dore-westbury/
I will also be making a few tools along the way in order to perform some of the repair work and for making any new parts to replace those that are too worn or damaged, so this could be quite the adventure.
So far I've stripped her down and I'm now cleaning up all the parts.
Pt1
https://youtu.be/3WjRtINyIzo
Pt2
https://youtu.be/j6vt-usZ-4Q
Update
https://youtu.be/K-6mgnq5iUo
Update #2
https://youtu.be/UJfYNq0hLwE
Pt3
Update #3
https://youtu.be/G9WGm34NXko
Pt4
https://youtu.be/4xM4K1DhKDM
Update #4
https://youtu.be/_PbCNnR_C8Q
Pt5
https://youtu.be/L96WDK1nU3o
Update #5
https://youtu.be/sQ97WuyV87Y
Pt6
https://youtu.be/O-v8puRumsI
